I have a building that requires large text to be recessed into the wall for branding. It will be inscribed into a wall family. Does Revit have the ability to create a void extrusion using text?
What would be the best method to achieve this?
Solved by syman2000. Go to Solution.
Check this video
https://www.youtube.com/watch?v=_PvOTnHxNA8&ab_channel=BinHe%E2%80%98sRevitStudyChannel
Create solid model text, join geometry to the wall, switch join order, then hide the text.
