3D dwfs's from Revit creating multiple copies of linked files.
Message 1 of 19
Anybody have any idea why when exporting to a 3D DWF from Revit I get multiple instances of the other linked Revit models included the file?
Replies (18)
Message 2 of 19
Do you have phases or design options?
Message 3 of 19
Yes, have design option.
Message 4 of 19
Viveka_CD
Hi @Anonymous
Can you try an audit and purge and see if the issue occurs again?
I look forward to hearing from you!
Message 5 of 19
Hi, no that didn't work. Trying to remove the design options now as mentioned above.
Message 6 of 19
Viveka_CD
Hi @Anonymous
Sure, please try and let me know or else you are welcome to share a file to test on our end.
Looking forward to hearing from you!
Message 7 of 19
Removing all the design options from both files didn't resolve the issue. Yes, you're welcome to look at the files, where can I send them? Thanks
Message 8 of 19
Viveka_CD
Hi @Anonymous
I've shared a private upload folder with you.
Please upload your journals, Revit files and other files we need for diagnosis using the collector extractor folder I've uploaded here. Let me know if you have any questions.
Please see article: Revit - Collecting and sending diagnostic data to Autodesk Technical Support
Let me know if you have any questions and when you are done with the uploading.
Message 9 of 19
Hi, I've copied the journal files etc into the shared folder but I don't seem to be able to copy my Revit files to the same folder?
Message 10 of 19
Viveka_CD
Hi @Anonymous
I've changed permissions, can you please try uploading again?
Message 11 of 19
Thanks, have uploaded the Revit files.
Message 12 of 19
Viveka_CD
Hi @Anonymous
Thanks for uploading!
I received your files. Can you also share a screencast so it will help me reproduce your issue with the exact same steps and file a problem report to investigate further?
Thanks again for your response!
Message 13 of 19
Hi Viveka.
Here is a link to the screencast also.
https://autode.sk/2AVO2mE
Steve
Message 14 of 19
Viveka_CD
Hi @Anonymous
I'm unable to view the screencast, can you send me a link through screencast.com
Message 15 of 19
Hi @Viveka_CD I've given you access to the screencast hopefully you'll be able to see it.
Thanks Steve
Message 16 of 19
Viveka_CD
Hi @Anonymous
Its been a while, so I'm sharing an update with you:
The issue is in progress and development is looking at your files. They have requested for another screencast since the one you've shared isn't clear. You'll have to fix the red border before you start recording (particularly if you've got multiple monitors)
Message 17 of 19
Hi
Message 18 of 19
Viveka_CD
Hi @Anonymous
Thanks for posting! I'll take a look and let you know.
Message 19 of 19
Hi
Any progress with this?
