2D Tree family nested masking region does not mask in Project
Sahay_R
Mentor Mentor
Sahay_R
Please take a look at the attached family. The lines and the masking region were created in separate nested Detail Item families, then both were nested into the plant family. It looks great in the family editor, but when I drop it into a project the masking region disappears. Help!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Try this.
Sahay_R
What did I miss?
Rina Sahay
I am not sure.  I had spent 5 minutes trying and gave up.  But there are more than one way to skin a cat.
Sahay_R
Then what did you do?
Rina Sahay
You didn't open the file?  I got rid of the masking region family and modified the line family to do what you need.
From my experience, a masking region must be in the same family as the other detail items in order fro you to send it above to mask them.  When you separate them two different families, you lose the ability to change the draw order.
Sahay_R
Thank you. I was off the grid, hence the question. Your solution (and explanation) makes eminent sense.
Rina Sahay
