2026- some levels not showing in linked model
jledgewood409
jledgewood409
i have a model (model A) which i added two new levels and i then linked model A into model B. while in model B i cannot see those two new levels. all the levels are on the same workset.
any thoughts?
omarselim
This happens a lot in Revit — it’s not that your new levels don’t exist in Model B, it’s usually that they’re just not visible because of view-specific visibility settings in the host model.
Here’s the main checklist to fix it:
 Check if the levels are visible in the linked model itself
  • Open Model A directly.
  • Make sure the two new levels are indeed there, not hidden, and visible in the relevant views.
  • Ensure they have a view range that would allow them to appear in an elevation/section.
 In Model B: Adjust the Visibility/Graphics for the link
  • Go to the view where you expect to see the levels (likely an elevation or section).
  • Press VG (or go to View → Visibility/Graphics).
  • Go to the Revit Links tab.
  • Set the Display Settings for your link:
    • Choose CustomAnnotation Categories.
    • Make sure Levels is checked.
    • If By Host View is used, switch to By Linked View and choose a linked view from Model A that already shows the new levels.
 Check scope boxes
  • If Model A’s levels are assigned to a scope box that isn’t visible in Model B, they won’t show.
  • In Model A, either remove the scope box from those levels or ensure Model B has a matching scope box visible.
 Workset visibility
  • Even though you said they’re on the same workset, check View → Worksets in Model B to make sure that workset is visible for that view.
 Elevation extents
  • In Model A, the level heads (annotation) might not be extended far enough to intersect your view in Model B.
  • Open Model A, stretch the level line so it crosses the linked view’s section/elevation line area.
BIM manager with 19 years of experience.
The Universitat de BarcelonaThe Universitat de Barcelona
Master in Global BIM Management for Infrastructure Projects
Research Assistant at Qatar University
being honoured at Autodesk Digital transformation summit for the Egyptian government, for spreading and supporting the BIM culture, and community development regarding the digital transformation of the construction sector
General manager of BIMarabia Research, BIM Dictionary's
RDAOU
Most likely the levels you mentioned are not cut by the section or elevation. Reopen the link and max their extents  or use a scope box. Then reload the link
jledgewood409
come to find out it had something to do with desktop connector not connecting to the file. once i resolved the DC issue everything began working.
