Now in v2026, I'm trying to create a toposolid for a slope that covers 50 feet of elevation change. I made a toposolid 100' thick. I tried making it variable thickness, and non-variable, both have the same problem. I set the elevation for it at the highest elevation and am trying to add points along contour lines (a .jpg underlay) that get progressively lower at 10' intervals. I tried it the other way, too placing it at the lowest elevation and working up. Both have the same problems.
Problem 1). When I place points along the line at a prescribed elevation they go where I tell them to, let's say 7,800' but only the first contour line. When I make the next contour line (7,790'), even if I prescribe the desired elevation in the new points, Revit places the point at whatever the resulting elevation is from the previous contour line (like 7,994'-3 11/32" or whatever).
Problem 2) I could just go back and edit them after they're placed to adjust their elevation, but I can't select more than one point at a time. When I drag around the points, they do not get selected / do not respond to the selection. Ctl-clicking on them doesn't select them either so I can't 'batch change' a bulk of them at a time there are a thousand or more points needed and editing them one by one is a no-go, even if it did work because none of them stay put after I change the one next to it. Any help would be greatly appreciated.
