(2023) railing repeating pattern
jledgewood409
Message 1 of 21
jledgewood409
i have created this railing (fence) that balusters and baluster panels. i am having a hard time getting the repetition to space correctly. see attach revit file
Replies (20)
Message 2 of 21
what are we looking for?  Nothing's jumping out as peculiar.
Message 3 of 21
jledgewood409
if you were to extend any of those railings you will see that the spacing doesnt keep.
Message 4 of 21
Truncate Pattern.
Message 5 of 21
Because a baluster panel has a fixed length dimension.  Design the length of your railing to fit the number of panel, or with gaps where make sense.
Message 6 of 21
jledgewood409
would you be willing to create an example with one of the railing in the file and upload it?
Message 7 of 21
So, you want to know if I would be willing to fix all these baluster patterns out of the kindness of my heart?  Don't you have something more fun?  😉
Message 8 of 21
here's a quick fix:
Message 9 of 21
Message 10 of 21
jledgewood409
thank you. i will give it a try.
Message 11 of 21
Here's one freebie:
Message 12 of 21
jledgewood409
thank you very much
Message 13 of 21
Here; maybe this will help too:
NOTE: This defines the Main Pattern - the thing that will be repeated.
Message 14 of 21
jledgewood409
ToanDN,
i am trying to recreate your screen shots as to where the railing start begins with the 3" square baluster followed by the panel. i am matching your "edit baluster placement" window and for some reason the start of my railing begins with the panel? any thoughts? i am attaching a file that reflects this situation.
Message 15 of 21
ToanDN,
Define the pattern exactly as I'm showing in message #11 and message #13.
Message 16 of 21
ToanDN,
You missed one thing.
Message 17 of 21
jledgewood409
i realized i didnt have it set to center just after i sent the message. thank you for all the help
Message 18 of 21
That's the only solution credit you intend to award here, @jledgewood409?
Message 19 of 21
jledgewood409
the thank you was intended for all of the above. so thank you
Message 20 of 21
I'll take a solution credit please.
