2017 - Text Glitch
2017 - Text Glitch
jcortelyou
Message 1 of 63
2017 - Text Glitch
jcortelyou
So when you type text in the new text box, the curser moves one way and the text moves another!!!!  What's up with that?!!  It also greys out the text when you edit it.  So much for new improvements....  Any fixes, please let me know.
Replies (62)
Message 2 of 63
RDAOU
@jcortelyou
Working fine here ... But I'm guess; try right side of the keyboard ALT+SHIFT and right side CTRL+SHIFT
Message 3 of 63
jcortelyou
Hmmmm....  Was going to try your suggestion but now it's working normally!!  I'll report back if it glitches again.
-j
Message 4 of 63
text glitches are the least of my worries. I just discovered all our annotation families have been affected. Titleblocks, keynotes, view references, schedules, if it has text in it, chances are something has changed. I will have to set aside time to fix the size of all our tag families. Yeep-pee!
Message 5 of 63
jcortelyou
Yuck!! Have you tried opening existing dwgs sometimes when I'm going quick I forget they won't scale properly until the view is dragged to a sheet. I know this is obvious but just thought I'd mention.
Message 6 of 63
L.Maas
Autodesk has changed the way fonts are measured in Revit. HERE a little bit of explantation
Louis
Please mention Revit version, especially when uploading Revit files.
Message 7 of 63
Yes, I wrote about it earlier today about some testing I did on a couple of my projects.
http://revitlink.blogspot.com.au/2016/04/upgrading-to-revit-2017-text-issues.html
What is worse, I have half a dozen sample projects I use for teaching & training, which I will have to painfully work through and fix.
Message 8 of 63
Keith_Wilkinson
There was always going to be some pain with this but there should be long term gain so I figure it's probably worth it.  And lets be honest the text editor has been one of the most complained about features of Revit since pretty much the beginning, at least now ADesk have started to address the issues.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Message 9 of 63
RDAOU
Revit 2017 is ONE WEEK old!! Tiny bugs here or a glitch there is something very normal lol in Autodesk Products...Who doesn't recall the number of updates and patches issued for 2015!! So my guess is; give it 2-3 months and you will start seeing those patches and SPs rolling
Beta testing was out for a while but unfortunately users enrolled in that beta testing aren't able to capture everything...So I would put it this way "There is no better way to test a product than putting it out in the market"
Irony is...Autodesk should PAY US ALL or  at least Reward users with something!!!
Message 10 of 63
Keith_Wilkinson
haha, why pay someone when you can get people to do it for free!  Smiley Wink
We do intend to roll out 2017 but probably only on new projects initially and probably not for another few months until the initial 'obvious' bugs are ironed out.  If you are going to be an early adopter you need patience.
Maimonides
Message 11 of 63
haha pay me?! Oh that would be nice! I would just be happy if Autodesk didn't charge for things that use to be free. Apparently their is a fee now to order the media if you don't/can't download!! what the...?! So now it's set aside 5hrs for installation or pay. I get 4cents a litre off petrol if I spend more than $30 at the local supermarket, but $8000 isn't enough for a USB stick... hahaha gold.
Text update problems aren't too bad, update a few families and push them back into the projects. Notes will be the annoying part, although i will play with minor adjustment to text size to try and compensate. As Kieth mentioned, we will only start new projects in 2017.
Message 12 of 63
There has been a fee since Revit 2014.
Message 13 of 63
csduncan157
Ditto here, I'm having the exact same glitch on our workstations. It's very difficult to work on larger text blocks with this happening. Bugged out text boxes are no bueno!
Message 14 of 63
2014.. really? Hmm, I ordered media last year for 2016 and wasn't charged. Anyway, 2014, 2017, it use to be included.
Message 15 of 63
jcortelyou
Well the problem has come back, I'm going to edit the accepted solution tomorrow. I'm also going to try a new keyboard to see if that works. We should all post hardware and os software specs to see if it's something easily identifiable. Oddly I'm having a CAPs problem with ACA that is reversing caps so I'm wondering if something didn't get changed on Windows Registry side of things.... Will report back.
Message 16 of 63
jcortelyou
Hey - Please post if you found any solutions for this!  Are you running Windows 10?  I've marked this thread as unsolved again as the problem is still occuring on my end.
-j
Message 17 of 63
treyk
Hi Everyone--
The New Text team has recently noticed this also.  Oddly, it's not an issue with New Text (or text at all)... instead, there is a bizarre glitch that will very occasionally (and seemingly randomly) cause a view to be interpreted by Revit as being mirrored.  We can get this to happen most often when opening a view containing a stair while slightly zooming with the mouse wheel.  As you've noticed, the next time you close and open the view, everying will very likely be fine.
When this mirroring happens, the most user-visible issue is the text editor--which is pretty much working correctly in the bizarro-world mirrored view.  So, we're working on correcting this weirdness very soon!
Thanks for your vigilance!
Trey
TreyKlein
Principal Revit QA Analyst
Message 18 of 63
jcortelyou
Thank you Trey!
-j
Message 19 of 63
jrbroadway
What's worse about this whole thing is that I am working on projects and the text editor glitch makes it almost impossible to edit notes.  I did not have this issue with Revit 2016 or earlier.  If I could, I would save my project down from 2017 to 2016 so that I could still earn a living until the patch comes out; however, Autodesk fears that me making a living may keep me from sending in that subscription check each year, so I am not able to save my work down to 2016.  In my business, I check my work to make sure it is correct before it goes out.  There are minor mistakes here and there, but the Text Editor in a cad package is a major component.  One would figure that Autodesk would test a major component of their product before releasing it.  Idiocracy is a documentary.
Note to self:  don't upgrade software until at least 6 months after the release date.
Message 20 of 63
Can we get an ETA for a fix on this Trey? The issue is rampant in every project we've started in 2017 on each of our PC's. We really need a solid solution here guys (software update, not a workaround)...thanks.
