2017 Text Editing Is Useless!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I first heard that Revit 2017 included a new and improved text editor, I was pretty excited as I'm sure many others were. However after actually using it, my views on it have drastically changed.
This is THE WORST text editor I have ever used in any program!
- You can't copy and paste text from other program such as MS Word or One Note. I have to first open 2016. Paste the text in there then copy it and paste into 2017.
- After you fight for an hour to get the formatting of your notes in a way that works (not the way you want because Revit can't do that) it completely changes the moment you click outside of the text box.
- When I select a textbox, highlight the text i wish to change and start typing, nothing happens... I mean it just stays as if I never started typing. This happens about 75% of the time intermittently.
- If I changes the bullet style for an indented section, it will often change the bullet style for everything above it as well and screw up all my indents.
- The spaces between the bullet and text are unnecessarily large and cant be changed.
- You can't insert a blank line in between paragraphs.
- If you, heaven forbid, change the size of your text box after formatting it will completely ruin all your formatting putting overflow text on new bullet-ed lines like they are a completely new sentence.
- If your sentence does not fit all on the same line it will wrap to the next line but completely ignore any indenting from the line it started from.
How is this an improvement?!? It just took me 3 hours to get notes for a Door Schedule into my project. I'd rather have the old text editor where I just fake the formatting with tabs and spaces.
Am I don't something wrong here? How does Autodesk think this actually works?
