Message 1 sur 3
2017 Deployment Doesn't Complete
- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Lien permanent
- Imprimer
- Signaler
I've created a deployment for BDS 2017. When I run it (as a logged in local administrator), the deployment reaches near completion at which point I receive the following prompt to Extract To:
I have to click cancel, at which point the deployment seems to conclude. Revit does install successfully.
The only item set to install from this (simplified) deployment is Revit - all other options have been unchecked. I originally ran into this issue from another deployment that included AutoCAD, 3ds Max, and other recommended software - I created the Revit only deployment to try to isolate the issue in case it was one of the other applications causing the problem.
Anybody else seeing this or have any suggestions? Thanks very kindly!
-Dan
