Revit 2016 install
Revit 2016 install
Message 1 of 8
Revit 2016 install
I am trying to install Revit 2016 in my laptop but cant find the link to dowload it from AutoDesk website; i found the link for 2017 but I need the version before that not 2017; can you send me the link for it?
Adriene
443-878-4645
Replies (7)
Message 2 of 8
DarrenP
Try downloading from here
https://knowledge.autodesk.com/customer-service/account-management/software-downloads/previous-versi...
Please accept as a solution if this fully resolves the issue
Its under Revit Products
DarrenP
Message 3 of 8
It does not work - I don't see Revit 2016; can you send a link for revit architecture 2016?
Adriene
Message 4 of 8
DarrenP
i just checked revit architecture 2016 is in the virtual agent
check again
DarrenP
Message 5 of 8
Does it come Part 1 and Par 2?
Thank you,
Adriene
[cid:image001.gif@01D055C2.916A8D00]
adriene fox
RA
PROJECT ARCHITECT
sba 8(a) | sdb | 8(m) edwosb | 8(m) wosb | dot dbe
e: a.fox@edificesolutions.com | p: 202.499.5980 | w: edificesolutions.com
Specialty Design+Build Mission Support
[Inc500_medallion_emailsig]
Message 6 of 8
DarrenP
yes you need to download both parts
DarrenP
Message 7 of 8
Now it is asking me to run the installer manually - how can I do that?
Adriene
Message 8 of 8
David_W_Koch
Double-clicking on Part 1 will start the self-extraction process (of both parts); when that is done, the installer should start.  If you already extracted the files and the installer did not start, if you go to the root folder of the extracted installation files, you should find a file called Setup.exe.  Double click on that file.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
