2015 to 2016 adaptive points
I made an adpative componet for travel distance paths in 2015. When I use this same component in 2016 the locations of the adaptive points can no longer be individually tab selected and adjusted. I have changed the points to placement points (adaptive) and have also tried Shape handle points (adaptive) to no avail. what do I need to change to get back the operability I had with the family in 2015?
josemukalel
Jose George
Architectural BIM/CAD Technician
josemukalel@gmail.com
+64 22513 0828
A KUDO is always welcomed; However, WHEN the above answer helps and/or clarifies your query; kindly mark it with ACCEPT AS SOLUTION
