1st Floor Walls are Not showing up on 2nd floor floorplan (level)
cliftonmaggard
cliftonmaggard
1st Floor Walls are Not showing up on 2nd floor floorplan (level). Have tried adjusting ranges ect nothing works. I'm new to Revit. Using Revit 2022.
Thanks CMaggard
cliftonmaggard
ADDITIONAL PROPERTY SHOTS
Check the Phase of the view and make sure it matches other (showing correctly) view.
RDAOU
..  didn't see previous reply
cliftonmaggard
This was the problem,  "PHASING " settings.  I have no idea what Phase means at this point. How did this get set different,  I have no idea. You are the man Thanks !!!!!!
cliftonmaggard
You nailed it!!  that was the problem.  How this got set different I have no idea.  THANKS !!!!
