Working With A Revit Model
omorah
omorah
Revit 2019
I am still having problems understanding using a Revit project as a model in these two scenarios:
- Say an architect's file with say four floor plans in the same project, side by side.
or
- An architect's project with demolition and new plans using the same floor plan in different views.
1. How to use this linked file as a model in my new project with the model's view?
2. How to control visibilities of each scenario to be able to see all elements as seen in the original model?
I have played around with some tutorials with architectural floor plans, but need one with the two above
scenarios, to practice with. Hope I am clear enough with clarifying my issue.
Thanks.
jeremytammik
Dear Omorah,
Welcome to Revit!
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
