Labed Issue In Title Block
omorah
omorah
Revit 2019
I am still new with Revit. This issue only occurs in this particular project. Sure it has to do with a setting in it I don't know what to do. If I insert the title block in another project, new or old, all will be fine. Please see attached file for more explanations. I cannot edit the label (at red arrow).
Thanks.
jeremytammik
Dear Omorah,
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
