File Path Display?
File Path Display?
omorah
File Path Display?
omorah
Revit 2019
In AutoCAD, there is an option to display the file's file path at the top of the screen, lilke the attached project file.
Is such possible in Revit?
jeremytammik
I am not aware of any such option.
However, this may not be the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, if your question is coming from an end user perspective, you should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
