Windows form on same screen as revit
Gilles.Lagrilliere
Message 1 of 9
Gilles.Lagrilliere
Hello
I made a plugin where a form appears if I click on my plugin button.
I work with a laptop and have two additional monitors.
the form always pop ups on my laptop screen, instead I want it to pop up on the screen where Revit is running.
How can I accomplish this?
I hope you guys can help me with this
thanks in advance!
Replies (8)
Message 2 of 9
RPTHOMAS108
Set the parent as Revit window via it's handle
Form.Show(Owner) or Form.ShowDialog(Owner)
Then set Form.StartPosition to CenterParent.
Message 3 of 9
Omar_Amen
Hi @RPTHOMAS108 ,
I don't know how can I get the (owner) Arg. from Revit API,
it's seems that it needs IWin32Window object but I don't know how to retrieve it
Message 4 of 9
Gilles.Lagrilliere
hello
check this link out: https://thebuildingcoder.typepad.com/blog/2010/06/revit-parent-window.html
this helped me to get IWin32Window object.
Message 5 of 9
RPTHOMAS108
Not used forms in a long while but I would probably try this:
 Public Function Obj_211130a(commandData As ExternalCommandData, ByRef message As String, elements As ElementSet) As Result
        Dim app = commandData.Application
        Dim uidoc = commandData.Application.ActiveUIDocument
        Dim IntDoc = uidoc.Document
        Dim F As New System.Windows.Forms.Form
        F.StartPosition = WF.FormStartPosition.CenterParent
        F.ShowDialog(New RvtWindow(app))
        Return Result.Succeeded
    End Function
    Public Class RvtWindow
        Implements Interop.IWin32Window
        Private IntHwnd As IntPtr
        Public Sub New(App As UIApplication)
            IntHwnd = App.MainWindowHandle
        End Sub
        Public ReadOnly Property Handle As IntPtr Implements IWin32Window.Handle
            Get
                Return IntHwnd
            End Get
        End Property
    End Class
Message 6 of 9
Omar_Amen
thanks both worked 😊
Message 7 of 9
jeremy_tammik
Note that the post from 2010 os obsolete and has been superseded by:
Two new properties in the Autodesk.Revit.UI namespace provide access to the handle of the Revit main window:
  • UIApplication.MainWindowHandle
  • UIControlledApplication.MainWindowHandle
https://thebuildingcoder.typepad.com/blog/2018/11/revit-window-handle-and-parenting-an-add-in-form.h...
Message 8 of 9
Gilles.Lagrilliere
How do I make it work with the new properties?
I tried frm.ShowDialog(CommandData.Application.MainWindowHandle)
but that doesn't work.
Thanks in advance!
Message 9 of 9
jeremy_tammik
You need to convert it to the appropriate data type. An example of how this can be done is provided by the module CmdJumpToRevitPosition.cs in The Building Coder samples:
      JtWindowHandle h = new JtWindowHandle( uiapp.MainWindowHandle );
      JumpToPosition jumper = new JumpToPosition( view, h );
Look at the description of updating The Building Coder samples to use MainWindowHandle:
Please read the blog post more carefully before asking further questions. I wrote it to avoid having to repeat myself.
