Error in ExternalDefinitionCreationOptions
helsted
helsted
Hi
I'm trying to define a new instance of an ExternalDefinitionCreationOptions(string name, ForgeTypeId dataType):
string name = "Psi"
ForgeTypeId dataType = new ForgeTypeId("Number");
ExternalDefinitionCreationOptions options = new ExternalDefinitionCreationOptions(defName, dataType);
This works when I'm using the now-deprecated ParameterType.Number instead of ForgeTypeId. However, currently I'm getting this message:
I have little experience with ForgeTypeId. Am I using the class wrong?
jeremy_tammik
Look at the ForgeTypeId constructor documentation:
https://www.revitapidocs.com/2022/4777ba3d-8f1e-399c-8f3a-cca084b2d42b.htm
It constructs a ForgeTypeId holding the given schema identifier.
"Number" is not a valid  schema identifier. You can see a sample using ExternalDefinitionCreationOptions with a ForgeTypeId in The Building Coder samples CmdCreateSharedParams.cs:
Basically, it uses:
  ForgeTypeId _deftype = SpecTypeId.Number;
  var opt = new ExternalDefinitionCreationOptions( defname, _deftype);
  definition = group.Definitions.Create(opt);
helsted
Hi Jeremy
Thank you very much - that worked perfectly!
Kind regards
Mathias
