Why do Revit Set classes only implement IEnumerable instead of IEnumerable<T>?
JOfford_13
JOfford_13
The Revit API contains lots of "Set" classes such as ParameterSet, ProjectLocationSet, PlanTopologySet, etc that only go as far as implementing IEnumerable.  Is there any particular reason they don't implement IEnumerable<T> where T is underlying Revit class type?
I find myself always casting the set to the underlying type or explicitly defining the class when using for-each loops.
element.Parameters.Cast<Parameter>().Where(p => criteria);
foreach (Parameter p in element.Parameters) { // .. }
The fact that the Sets only implement IEnumerable makes me a bit nervous doing this.  Is the above considered acceptable/safe code in Revit?  Are there times when a Set like ParameterSet actually returns Objects that aren't Parameters?  If so, please clarify when I might expect such an event.
JimJia
Hi JOfford_13,
ParemeterSet is a set that contains parameters. All objects in it are paremeters.
So there is no need to cast object to Parameter, just use foreach as follows:
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
JOfford_13
Is there a reason then why the ParameterSet doesn't implement IEnumerable<Parameter>?  Why are we forced to cast it from an Object to a Parameter every time?
JimJia
Hi JOfford_13,
I am communicating with engineer team, will keep you updated once I get any information.
Jim Jia
r.terry
Any further information on this yet?
JOfford_13
any updates on this?
john_dalessandro
Until we get word back, there are a few workarounds you can do instead of casting. I usually use OfType, which gives you the typed IEnumerable that you can then use LINQ function notation on without having to cast each member of the set. You can also use the LINQ query notation. For example,  (in vb.net)
Dim test As IEnumerable = {1, 2, 3, 4, 5}
Console.WriteLine(String.Join(" ", (From n In test Select n * 2)))
Prints "2 4 6 8 10" successfully. For more on using query notation look here.
