Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to reduce size of columns in above floors without changing its parameters?
1 REPLY 1
515 Views, 1 Reply
How to reduce the size of columns (width & breadth) in above floors without changing the name of the column or creating a new one? Like a tapered column.
1 REPLY 1
naveen.kumar.t
HI @Anonymous,
In tapered column you can change the width and breadth by setting the tapered column parameter value
                    Element e;
                    foreach(Parameter P in e.Parameters)
                       if(P.Definition.Name=="Your breadth/width parameter name")
                            P.Set(value);
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Forma Design Contest
Rail Community
