Why Add-In Manager in the Revit SDK (2017 2017.1) has version 2014?
Message 1 of 23
It is great tool, it is work good. But I am not understand, why Add-In Manager in the Revit SDK (2017 2017.1) has version 2014?
It also create folder with name "2014".
Can I find somewhere a source to perform assembly itself?
Thanks in advance for answers..
Replies (22)
Message 21 of 23
matthew_taylor
Hi @jeremytammik,
I await their reply with great anticipation.
Thank you.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Message 22 of 23
jeremytammik
Dear Matt,
I am sorry to report that I have not heard back from the development team on this. Sorry about that!
On the other hand, I am happy to report that a solution has been presented in this other thread:
https://forums.autodesk.com/t5/revit-api-forum/revit-2020-addin-manager-missing/m-p/8774075
Apparently, the Revit 2019 add-in manager can be used in Revit 2020 as well.
Have you already noticed?
Or did you find some other solution?
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 23 of 23
matthew_taylor
Hi @jeremytammik,
Thanks for the update.
Yes, I noted that above. Smiley Wink
I've had no issues with the 2019 add-in manager in 2020, so we seem to be okay until April next year... Let's hope it doesn't take that long to hear back from the dev team!
Cheers,
-Matt
