What is the use of XYZ normal in NewFloor() method?
My floor type is like this:
when I use the xyz(0, 0, 1) to create a floor, the result is:
when I use the xyz(0, 0, -1) to create a floor, the result is the same:
No matter which XYZ normal I use, the result is the same.
How can I create a floor like this? Let the yellow on top.
I look forward to your reply, thank you very much!
Richard
jeremytammik
Dear Richard,
Try to solve this in the user interface first, before researching a programming solution.
You may have to define a completely different floor layering with the yellow layer first (top) and the orange one last (bottom), inverting the order of the existing layering definition.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Dear Jeremy ,Thank you for your reply!
This problem can indeed be solved through the user interface.
I just don't understand where the difference between
public Floor NewFloor(
	CurveArray profile,
	FloorType floorType,
	Level level,
	bool structural
and
	CurveArray profile,
	Level level,
	bool structural,
	XYZ normal
jeremytammik
Apparently, it was intended to switch the top and bottom face, just as you expected:
http://thebuildingcoder.typepad.com/blog/2014/03/creating-a-sloped-floor.html
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Thank you for your kind answer
I have benefited a lot from many of your articles. I believe that as I get more and more knowledge of the API, I will understand the problems that are confusing me now.
对于众多在Revit二次开发道路上的人们,您是一位非常可贵的良师益友。//For many people on the road of Revit's secondary development, you are a very valuable mentor.
Good luck!
jeremytammik
Thank you very much for your kind appreciation and the best of luck to you too!
Jeremy Tammik
The Building Coder
