Appears in sheetlist
vanlion
vanlion
I'm looking for the parameter: appears in sheetlist. But i can't find it when you do a viewsheet filtered collector.
Anyone An idea how it's called or accessible?
BardiaJahan
Try to get this parameter:
BuiltInParameter.SHEET_SCHEDULED
vanlion
Hi BardiaJahan,
Thanks. That's the one i was looking for.
I receive the value as Yes or No with the part underneath:
get_Parameter(BuiltInParameter.SHEET_SCHEDULED).AsValueString();
 but if i want to set the value with "Yes" or "No" received from my checkbox it doesn't work:
get_Parameter(BuiltInParameter.SHEET_SCHEDULED).Set("my result from checkbox");
Do you know if it must be a string parameter or a bool? when i try a bool i get the error:
cannot convert bool to Autodesk.Revit.DB.ElementId
Thanks!
BardiaJahan
StorageType of Boolean (Yes/No) parameters in Revit is actually integer. It means if you want to set the value of such parameter you should use 0 as No/False and 1 as Yes/True. Try casting the bool from checkbox to int.
vanlion
Thanks!!!
You have made my day. Never thought of that but so easy 😉
