What is the difference "ElementIntersectsSolidFilter()" vs "Solid to Solids from Elements"
sahin.ikbal
sahin.ikbal
I have generated A solid with which I want to check if any other elements is clashing with that solid.
I know I can get it done through extracting solids from every element than using BooleanOperationsUtils to check for intersection.
I want to know does ElementIntersectsSolidFilter() do this job same previous one?
If different than how?
jeremy_tammik
I believe the results will be the same.
Please test this hypothesis and let us know the result.
If the solids are coming directly from the elements themselves, then using the element intersection filter might be slightly more efficient, because you save the performance hit of exporting the solid information from the Revit memory space to your .NET add-in.
When filtering for elements, you should always be aware of the differences between quick and slow filters, and the slower still post-processing of results in .NET.
sahin.ikbal
@jeremy_tammik
"Please test this hypothesis and let us know the result"
Wish someone else had confirmed it for me😁.
From the small number of testing I have done it's giving similar results so I'm assuming both are same.
