FailureResolutionType.DeleteElements is not working
I have a command that will open many models, process and close. However the command keeps stalling due to the following message.
Error-cannot be ignored.
Cannot form radial dimenshion.
I can continue to open the file by clisking the button of Delete Dimension(s).
Bug I want the program to handle this error automatically,so I  write the following codes.
Autodesk.Revit.ApplicationServices.Application app = commandData.Application.Application;
app.FailuresProcessing += HandleFailures;
public void HandleFailures(object s, Autodesk.Revit.DB.Events.FailuresProcessingEventArgs e)
FailuresAccessor failuresAccessor = e.GetFailuresAccessor();
failuresAccessor.DeleteAllWarnings();
var failures = failuresAccessor.GetFailureMessages();//获取所有的失败信息
foreach (var failure in failures)
if (failure.GetSeverity() == FailureSeverity.Error)//获得的是失败信息
string content = failure.GetDescriptionText();
if (content.Contains("Cannot form radial dimension"))
failure.SetCurrentResolutionType(FailureResolutionType.DeleteElements);
failuresAccessor.ResolveFailure(failure);
else
When I run the program, it catches the error and debugs normally.
But this window still appears.
What should I do to avoid this window?
jeremy_tammik
If you are certain that you want to suppress and ignore all warnings of all kinds, you could try using this warning swallower:
https://thebuildingcoder.typepad.com/blog/2016/09/warning-swallower-and-roomedit3d-viewer-extension....
I think that I've done it, but it doesn't make any difference.
There is a Error instead of Warning,so I writer following code.
I've tried this method ,and it doesn't work.
  foreach( FailureMessageAccessor f in failures )
   FailureSeverity fseverity = a.GetSeverity();
  if( fseverity == FailureSeverity.Warning )     {       a.DeleteWarning( f );     }
 else     {       a.ResolveFailure( f );       }
jeremy_tammik
If all else fails, as a last resort, you can dismiss the dialogue with the native Windows API:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.32
Look at the first article in the list.
Sean_Page
Make sure your setting the processor handling result.
e.SetProcessingResult(FailureProcessingResult.ProceedWithCommit)
And that is on the eventargs "e".
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
Sean_Page
I also might suggest using the DefinitionId and resolution types rather than searching the content string.
//This is when you know the resolution and don't care what the error is
if(fas.IsFailureResolutionPermitted(fa, FailureResolutionType.DeleteElements))
fa.SetCurrentResolutionType(FailureResolutionType.DeleteElements);			fas.ResolveFailure(fa);
//This is when you want to check for a specific error and just resolve using the default resolution
if(fa.GetFailureDefinitionId() == BuiltInFailures.FamilyFailures.FamilyIsCorruptError)
Thank you very much and I'll take your advice.
