wall join showing wrong in elevation
I have three walls joining in one corner. I have joined the two main walls and the third one I've cut with a void for the corner to look correct in plan views. For some reason this third wall joining the corner shows a white gap in elevation even though the third wall is joined to the corner without any gap. I've zoomed to the corner as close as you can and there´s not even a 0,1 mm gap in between the two. Why is this happening and how can i fix this so that the elevation look correct?
jeremytammik
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Posting this on API forum was a mishap, sorry!
