Cannot set base-top constraint of slanted column
Hi guys, I encountered an interesting problem today that I want to share with everyone and hopefully someone can shed some light into the matter.
So I created a bunch of slanted columns via the revit API with the method NewFamilyInstance(Curve, FamilySymbol, Level, StructuralType) Everything is fine, then I wanted to change the base and top level of the newly created column for scheduling later on. what I expected were:
expected propertiesexpected propertiesexpected snoopexpected snoop
However, after running my code to set the parameter what I had were:
result propertiesresult propertiesresult snoopresult snoopbase level parameterbase level parameter
The code I used to set element's parameter was:
            foreach (FamilyInstance column in columnCol)
                Parameter baseLevel = column.get_Parameter(BuiltInParameter.FAMILY_BASE_LEVEL_PARAM);
                baseLevel.Set(levelForBase.LevelId);
                Parameter topLevel = column.get_Parameter(BuiltInParameter.FAMILY_TOP_LEVEL_PARAM);
                topLevel.Set(levelForTop.LevelId);
I don't get why the base and top constraint turned null after running the code. I suspected the Level parameter(read only) of the element is set when I created the family instance, and cannot be changed via the API. However, I can still manually change base and top level parameters via the UI. Note that I did not receive any error nor  exceptions from Revit, and I used the same code to change other parameters without any problem. So can anyone help me understand this problem please?
Best reagrads,
jeremytammik
