		12:26 AM
- Mute
- Permalink
- Report
I have three walls joining in one corner. I have joined the two main walls and the third one I've cut with a void for the corner to look correct in plan views. For some reason this third wall joining the corner shows a white gap in elevation even though the third wall is joined to the corner without any gap. I've zoomed to the corner as close as you can and there´s not even a 0,1 mm gap in between the two. Why is this happening and how can i fix this so that the elevation look correct?
