Hello everyone and thanks in advance for the help. Basically when I'm doing a schedule or a material take off for walls the areas of the walls don't add up and instead it shows a blank space in the schedule. If I check 'itemize every instance' it does show the area of each wall but if I uncheck it to see the total area for every wall type it shows nothing.
Solved by caroline.gitonga. Go to Solution.
Thank you for this question. What you need to do is left click on your schedule on the project browser on Revit and open properties. On the Schedule properties, click on formatting Edit button, on Fields section, select Material:Area. On the right there is a dropdown input element with placeholder "No calculation", select "calculate Totals".
Note: On material take off schedules, use Material:Area instead of Area.
Thank you so much! such a rookie mistake, also I realized soon after posting that the API forum wasn't the correct place for the post so I'll take it into account for future post, thanks again!
