Visual Studio 2015 Update 2 and debugging Revit API addins
Hi there
don't know if this is the correct forum to ask....
Microsoft has enabled debugging lambda expressions in the Visual Studio 2015 debugger. This great!
However, this doesn't work when I am debugging Revit Addins
what a shame.... anyone here who has the same problem and found a way to fix it?
cheers
Jeroen
I faced the same problem which I upgraded to VS2015 from VS2013.
At the beginning I chose to apply same development environment as VS2013's, then the problem occurred.
I solved this issue with following steps.
[TOOLS]->[Import and Export Settings]->[Reset all settings]
Hopefully It would helps.
Hi thanks for the reply again and sorry I did not answer yet
It still shows an error (no longer the unable to evaluate lambda expressions
if for instance I have a collection of elements
_familyElements.Select(x =>x.Id) shows {System.Linq.Enumerable.WhereSelectListIterator<Autodesk.Revit.DB.Element, Autodesk.Revit.DB.ElementId>}
but when I open this
Error The debugger is unable to evaluate this expression
You can just add a little  expression "Enumerable.Range(0, 100).Select(i => (float)i / 10).ToArray()" to "watch" for checking lambda debugger works or not.
But yes,I think there's some capability issues or limitations with combination of Revit classes and lambda expression(I've tried revit 2016).
Maybe it would have a workout in further releases.
