2D View Orientation Vector
Hi everyone !
I'm developping a plugin for Revit and i use view3D.GetOrientation() which is very usefull to get the upDirection and forwardDirection vectors. Unfortunatly this method works only with a view3D. Is there a method to get similar vector when the currend view is a 2D view  ? For example i'm working on South Elevation view and i want the method to return
XYZ upDirection = new XYZ(0, 0, 1);
XYZ forwardDirection = new XYZ(0, 1, 0);
I could get every cases using a very huge Use Case but it would never fit every situatiuons.
Any hints ?
Thanks!
Revitalizer
see View.UpDirection, View.ViewDirection, View.RightDirection and its View.Origin properties for the view's orientation.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Hey ! Thanks a lot. Unfortunatly i can get but i can't set these properties as they are Read-Only, do you know a way to set them ?
Revitalizer
you could try to set the Transform property of the View's BoundingBox.
http://thebuildingcoder.typepad.com/blog/2012/06/create-section-view-parallel-to-wall.html?cid=6a00e...
I tink that will not function with arbitrary values since each view type has its limitations (ViewPlans alsways with XYZ.BasisZ Viewdirection etc.).
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
