Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Visibilite et Masquage des objets dans les vues.
2 REPLIES 2
beyaUEY2P
113 Views, 2 Replies
Bonjour,
J ai une preoccupation...(Sorry pour les accents sur les mots francais)
En fait, toutes les fois que j'ajoute un nouvel objets (toposolid, modele generique etc.) dans un model, cet objet apparait sur toutes les vues et par consequent toutes les feuilles (si sa categorie n'est pas masquee). Du coup ca donne le job d'aller reviser toutes les vues où on ne souhaite  pas voir l'objet.
Dites moi, est ce possible, en creant un objet de dire si on veut le voir sur une vue specifique et ainsi eviter de le voir ailleurs, sans etre obligE de le faire vue apres vue ?
Merci bien pour qui voudrait m'aider !
2 REPLIES 2
jeremy_tammik
in reply to: beyaUEY2P
Google translate says:
Q: Every time I add a new object (toposolid, generic model etc.) in a model, this object appears on all views and therefore all sheets (if its category is not hidden). So it gives the job of going to review all the views where we do not want to see the object. Is it possible, when creating an object to say if we want to see it on a specific view and thus avoid seeing it elsewhere, without being obliged to do it view after view?
A: I would assume that yes, this is possible. However, unfortunately, this is not the best place to ask such a question. Please note that this discussion forum is dedicated to programming Revit using the Revit API. Afaict from your query, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface. In that case, you will probably get more optimal answers to a question like yours relating to product setup, optimisation, usage, best practices and other end-user support issues in one of the non-API Revit product support discussion forums instead:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
beyaUEY2P
in reply to: jeremy_tammik
Great !
Thanks for redirecting me sir.
Forma Design Contest
Rail Community
