ViewDrafting : missing ViewFamilyType
Hi Folks,
In a custom plugin, I have to create a new Drafting View, and I do the following :
var vft = new FilteredElementCollector(doc).OfClass(typeof(ViewFamilyType)).Cast<ViewFamilyType>().FirstOrDefault(t => t.ViewFamily == ViewFamily.Drafting);
var draft = ViewDrafting.Create(doc, vft.Id);
This worked like a charm, until I found a customer's project that didn't contained any ViewFamilyType of type Drafting.
It seams to be a fatal issue, because :
- Second argument is mandatory (i.e cannot be NULL nor ElementId.Invalid) in ViewDrafting.Create(doc, id)
- There is no API call to create a ViewFamilyType from scratch (Duplicate is not suitable because there is no element to duplicate ...)
Am I toasted ?
Thanks for help 🙂
TripleM-Dev.net
The ViewFamily's always contain at least one type, the last one can't be purged or deleted.
I've tested if the last one could be deleted by the API, it can't.
So there's something wrong.corrupt with the document.
I always build in a check if it's a valid ElementId (compare against ElementId.InvalidElementId).
And if it's invalid give the user a message something is corrupt/missing in the document.
(copy a draftview from another project to get a drafting type back.)
I wonder, can you create a Draft view in the UI if there's no Drafting type?
- Michel
TripleM-Dev.net
See this post, fault in a certain language template:
https://forums.autodesk.com/t5/revit-api-forum/drafting-view/td-p/6300235
The document contains many ViewFamilyType, but none of type ViewFamily.Drafting.
And yes, by means of direct Revit UI manipulation, I can create a new Draft View despite the fact that no ViewFamilyType of type Drafting is present.
TripleM-Dev.net
And after the DraftView is created by the UI, then a type exists?
If so, just report the User a Type is missing and to create one by the UI. (possibly state the Fault in certain Templates
And would be good that those Templates/projects get fixed.
- Michel
After manual Draft View creation, there is no new ViewFamilyType, but I can use View.Duplicate().
The missing type in French (at least) Template is an old topic (2016).
The faulty project is from Rvt2020, but I guess it is from an updated Rvt2016 initial project, created with the faulty template, hence the missing types.
