Can I isolate objects in linked file
ottosson_mathias
ottosson_mathias
I want to isolate an object from the open model together with an object from a linked model. Is this possible somehow?
This code snippet only isolates the object from the current model, and "objectFromLinkedModel" is hidden:
var isolatedObjects = new List<ElementId>()
    objectFromCurrenntModelId,
    objectFromLinkedModelId
using (var transaction = new Transaction(doc, "Isolate elements"))
    transaction.Start();
    current3DView.IsolateElementsTemporary(isolatedObjects);
    transaction.Commit();
In the best of worlds I'm able to use IsolateElementsTemporary, but if that doesn't work, are there any other method to quickly hide all elements except those that I want to isolate? If I collect all elements and hide the in a loop, it's unfortunately reeeeally sloooow and does not work on large models.
Thanks!
RPTHOMAS108
I believe you can't temporarily isolate elements from a link in the UI, therefore you will not be able to do so with the API.
ottosson_mathias
So my suspicions were true... Do you know any other way to isolate a few specific elements without having to loop through every single object in the model and set them to hidden? Preferably just as fast as IsolateElementsTemporary.
