view.HideElements() does not work in Revit 2024
natasa.jugovicNDJGN
natasa.jugovicNDJGN
HideElements() method doesn't work in Revit 2024 (and 2023).
I am trying to hide connector in the family.
Hiding elements temporary is not a solution for me, because it will be visible again after closing and opening family again.
I attached a family and here is a code sample.
This was working in 2022.
Any news about this issue?
public class Command : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            Document document = commandData.Application.ActiveUIDocument.Document;
            View activeView = document.ActiveView;
            FilteredElementCollector collector = new FilteredElementCollector(document, activeView.Id);
            List<ElementId> connectors = collector
                .OfCategory(BuiltInCategory.OST_ConnectorElem)
                .WhereElementIsNotElementType()
                .ToElementIds()
                .ToList();
            Element connector = document.GetElement(connectors[0]);
            using (Transaction transaction = new Transaction(document))
                transaction.Start("Hide Connectors");
                bool canBeHidden = connector.CanBeHidden(activeView);//returns true in 2022, 2023 and 2024 version
                if (connectors.Count > 0)
                    activeView.HideElements(connectors);
                transaction.Commit();
            return Result.Succeeded;
Nataša
jeremy_tammik
So, if I understand correctly, we can narrow down this issue to a bare minimum, can we? Would the following be a valid formulation of the problem you face?
  • Connector.CanBeHidden returns true in Revit 2022 and Revit 2023, and false in Revit 2024.
natasa.jugovicNDJGN
Connector.CanBeHidden returns true for 2024 as well.
Missed to add it, sorry for that. Edited it now.
