Electrical Wire not found in BoundingBoxIsInsideFilter
MikeM615
MikeM615
I am currently trying to locate electrical wires that exist within a dependent view's bounding box. However, I have not been successful in using methods such as BoundingBoxIsInsideFilter, BoundingBoxIntersectsFilter, or VisibleInViewFilter.
In order to obtain the wires' bounding box, I had to use wire.get_BoundingBox(viewTheyExistOn) to get any value for their location. Despite following Jeremy's example in message #4 of this link
https://forums.autodesk.com/t5/revit-api-forum/check-to-see-if-a-point-is-inside-bounding-box/m-p/43... I am still unable to get any wires into my list.
I apologize for the mess in my example snippets as I have been trying various approaches to make it work.
jeremy_tammik
I am not sure whether the filtered element collectors are ever able to take wire geometry into account. Do your wires have real geometry, e.g., a curve and a location? The filtered element collectors only deal with BIM elements and BIM element geometry. If your wires have valid geometry, it may not be recognised by them a valid BIM element geometry, so you will have to treat is as abstract pure non-BIM geometry and use other means than the filtered element collectors to retrieve it. So, yes, using a pure geometry bounding box sounds like a good way to go. Just be clear that this is completely separate from filtered element collectors.
MikeM615
Yes sir they do have a curve and location, I am able to find them just fine through the FilteredElementCollector for each View, except on a Dependent View.
The Dependent View will show all wires of the Primary View not just what is within its Crop Region. Took a few iterations but I finally found how to get the actual Crop Region of the Dependent View, the first few ways I tried gave me the Primary Views Crop Region, so I ended up having to get the extents from the BuiltInParameter
I also tried to extend my Z from that 1000' in either direction and it still did not show up, but if I invert any of those three filters, it finds all the wires of the Primary View even including the handful inside the Crop Region which shouldn't with it inverted.
This is the extents of the Dependent Views Crop Region:
And these are the wires within it:
Everything at face value looks like the filters should work, it just seems I am missing something simple.
Here is the section of code I used just to produce those values, but the BoundingBoxIsInsideFilter is failing on:
private List<Wire> WireCollector( ForEachView viewPlan )
            List<Wire> wireCollector = new FilteredElementCollector( _Doc, viewPlan.Id )
                    .OfCategory( BuiltInCategory.OST_Wire )
                    .WhereElementIsNotElementType( )
                    .OfType<Wire>( )
                    .ToList( );
            //If view is dependent view, filter wires by bounding box
            if ( viewPlan.PrimaryPlan != ElementId.InvalidElementId )
                ////Set Z value to 1 ft above and below level
                XYZ viewBoundingBoxMin = new XYZ( viewPlan.ViewBoundingBox.Min.X, viewPlan.ViewBoundingBox.Min.Y, -1 );
                XYZ viewBoundingBoxMax = new XYZ( viewPlan.ViewBoundingBox.Max.X, viewPlan.ViewBoundingBox.Max.Y,  1 );
                //Create Outline and BoundingBox
                Outline outline = new Outline( viewBoundingBoxMin, viewBoundingBoxMax );
                BoundingBoxIsInsideFilter boundingBoxIsInsideFilter = new BoundingBoxIsInsideFilter( outline );
                //Test Value Reporting
                TaskDialog.Show( "Wire Export", viewBoundingBoxMin.ToString( ) + " Min " + viewBoundingBoxMax.ToString( ) + " Max " );
                //Add elements to new list if passes filter
                foreach ( Wire wire in wireCollector)
                    TaskDialog.Show( "Wire Export", wire.get_BoundingBox( viewPlan.CropRegionElement ).Min.ToString( ) + " Min " + wire.get_BoundingBox( viewPlan.CropRegionElement ).Max.ToString( ) + "Max" );
                List<Wire> filteredWires = wireCollector
                    .Where( w => boundingBoxIsInsideFilter.PassesFilter(w) )
                    .ToList( );
                TaskDialog.Show( "Wire Export", $"There are {filteredWires.Count} wires in the view {viewPlan.Name}." );
                return filteredWires;
            else
                TaskDialog.Show( "Wire Export", $"There are {wireCollector.Count} wires in the view {viewPlan.Name}." );
                return wireCollector;
ricaun
I'm not sure the bound box filter does work with 2d elements that are owned by a view.
I guess in the bound box filter implementation, the filter tries to get the bound box of the element without a view, like element.get_BoundingBox(null), and the result would be null, resulting in a PassesFilter to false.
I guess the only way should be to create your own filter and add a View to use in the comparison (Gonna be a slow filter to use with Linq).
I created the BoundingBoxViewIntersectsFilter and BoundingBoxViewIsInsideFilter.
And here is a code sample to test, I put a big tolerance to force the PassesFilter to be true.
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.UI;
using System.Linq;
namespace RevitAddin.Commands
    [Transaction(TransactionMode.Manual)]
    public class CommandWireIsInside : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elementSet)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Document document = uidoc.Document;
            View view = uidoc.ActiveView;
            var wires = new FilteredElementCollector(document)
                    .OfCategory(BuiltInCategory.OST_Wire)
                    .WhereElementIsNotElementType()
                    .OfType<Wire>()
                    .ToList();
            System.Console.WriteLine($"Wires: {wires.Count}");
            var tolerance = 1e3;
            var viewBox = view.CropBox;
            var outline = new Outline(viewBox.Min, viewBox.Max);
            var boundingBoxFilter = new BoundingBoxViewIsInsideFilter(outline, view, tolerance);
            var wiresBox = wires
                    .Where(boundingBoxFilter.PassesFilter)
                    .ToList();
            System.Console.WriteLine($"WiresBox: {wiresBox.Count}");
            TaskDialog.Show($"Wires: {wires.Count}", $"WiresBox: {wiresBox.Count}");
            return Result.Succeeded;
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
MikeM615
Thank you @ricaun, that makes a lot of sense and matches what I was seeing in my results and assumptions, I definitely got stuck on the problem and couldn't think of a next step at all in the moment!
Thank you for the examples, that is exactly what I needed!
jeremy_tammik
Thank you very much for the great analysis and useful utility classes, @ricaun !
Shared here on the blog:
https://thebuildingcoder.typepad.com/blog/2023/05/aligning-elements-finding-and-visualising-wires.ht...
