Using RESX-files inside of Revit macros
Message 1 of 9
Revit 2017.1.1.
Usually I use RESX-files for localization of my applications. I work with their content through ResourceManager class. Of course, I create the default resources which are built-in into my target assembly.
Later, if I need then I will add some count of special localized resources: .\en\MyAssemblyName.resources.dll, .\ru\MyAssemblyName.resources.dll, etc. It is very convenient and I add new localizations quickly and without problems (when I need it).
As I mentioned earlier, I create the macroses inside of SharpDevelop as the first step of add-in's developing. Of course, I want to use RESX-files at this case too (at least the default resources). But built-in SharpDevelop can't handle such files. I added RESX-file manually but it doesn't work still. I get the compilation error:
> Inadmissible Resx file. Inadmissible data at the root level., line 1, line item 1.
> (MSB3103) - C:\ProgramData\Autodesk\Revit\Macros\2017\Revit\AppHookup\Sandbox\Source\Sandbox\ThisApplication.resx:1
Is it possible to solve this problem?
Look my attached screens, please.
Replies (8)
Message 2 of 9
Usual SharpDevelop which is not built-in into Revit application, works with RESX-files and build such projects without problems. And its compilation's result works in Revit successfully. But such SharpDevelop doesn't support the 64-bit debugging...
Look the attached screens, please.
Message 3 of 9
You should try to get some more attention for support of 64 bit with SharpDevelop...
Add 64-bit compatibility
Github - SharpDevelop Issues - 64bit
Message 4 of 9
jeremy_tammik
Dear Andrey,
Thank you for your query.
I'm sorry I only noticed it today.
Have you resolved the issue, or are you still stuck?
Did TeunHam's advice help?
I can raise an issue with the development team for this, if you like.
Can you provide a reproducible case and provide all the step-by-step detailed instructions?
I guess they would have to include how to set up the external stand-alone SharpDevelop IDE.
What do you think?
Thank you!
Best regards,
Jeremy
Message 5 of 9
Hi Jeremy,
I thought that you ignored my question. 🙂
No, I have not.
No, his advice is not related with my question.
I would be grateful to you at this case.
I showed to you expanded info how to work with RESX-files here: http://forums.autodesk.com/t5/revit-api-forum/why-the-language-key-switches-currentculture-instead-o...
Did you see it?
Why? It works without problems in stand-alone SharpDevelop IDE. The problem is with SharpDevelop IDE which is already built in Revit.
They can dowload and install stand-alone SharpDevelop IDE from its official site: http://www.icsharpcode.net/OpenSource/SD/Default.aspx
Also, I described some additional problems which are related with Revit's SharpDevelop here: https://revit-addins.blogspot.ru/2017/01/ide.html
Best regards,
Andrey
Message 6 of 9
jeremytammik
Ok, I'll look into it and raise an issue with the development team.
Meanwhile, here is a draft version of the blog post on the multi language support that I am working on right now:
file:///Users/tammikj/a/doc/revit/tbc/git/a/1523_multi_lang_resource.html
Please take a look and let me know what you think.
So many exciting new items in it...
More later...
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 7 of 9
I haven't access to your local computer. 🙂 Pay attention to your link - it is a local link instead of web-link.
Look my video what I mentioned to you in my previous message. I have a hope it will be helpful for you.
Message 8 of 9
jeremytammik
Sorry, my mistake, a cut-and-paste error:
http://jeremytammik.github.io/tbc/a/1523_multi_lang_resource.html
Jeremy Tammik
The Building Coder
Message 9 of 9
Delete the "My monologue is ended." sentence.
Jeremy, also I showed expected (right) behaviour in the video: https://www.youtube.com/watch?v=f1IBVgP7T1I&feature=youtu.be
I haven't other notes.
