- Mute
- Permalink
- Report
Is it possible to create a web app that manipulates a simple object in Revit "Beam for example".
The pure Revit API is a Windows .NET API that requires a running session of Revit and a valid Revit API context to execute, which is only provided within a running session of Revit.exe on a Windows desktop PC. You can however also use the Revit API in the cloud on a virtual machine directly from a web app by making use of the Autodesk Platform Services APS Design Automation for Revit API:
Developer Advocacy and Support + The Building Coder + Autodesk Developer Network + ADN Open
I had done some example practical before, this is some idea you can play with :
- Build the add-in and open a listener to get data from Revit : https://github.com/BIMrxLAB/Revit2GraphQL
- Use Revit Design Automation API
Chuong Ho
I was trying to understand where to start but this from the README looks broken https://marconi4revitwebapp.azurewebsites.net/
Do you have a time 30 minutes or something to talk a call about that.
thanks in advance
Hi @omarhassanmohamed_ahmed , can contact my email in case you need any help with that : [email protected]
Chuong Ho
I just want to add some point tutorial here for any interesting with learning Revit Design Automation with topic :
Part 1 : https://dev.to/chuongmep/use-revit-design-automation-update-revit-model-in-acc-part-1-1o31
Part 2 : https://dev.to/chuongmep/use-revit-design-automation-update-revit-model-in-acc-part-2-58kc
Chuong Ho
Thank you, Chuong, for the helpful pointers! Added to the blog for posterity:
