Access Cloud Models with Design Automation
peter_sylvester
peter_sylvester
I have a Revit DA application where I am trying to access an ACC model.
I've done as described in the docs.
My WorkItem in Postman looks like:
    "activityId": "{{dasNickName}}.NVCMActivityTXT+testTXT",
    "arguments": {
        "NVCMParams" : {
	    "url": "data:application/json, [{'Region': 'US', 'ProjectId': '062b8c8b-d33b-473f-9760-1e811629071a', 'ModelGuid': 'c20b5561-4f6b-4eb1-b9b7-84bfe163ff7a'}, {'Region': 'US', 'ProjectId': '062b8c8b-d33b-473f-9760-1e811629071a', 'ModelGuid': 'c20b5561-4f6b-4eb1-b9b7-84bfe163ff7a'}]"
    "result": {
        "url": "urn:adsk.objects:os.object:{{ossBucketKey}}/{{ossOutputFileObjectKey}}",
            "verb": "put",
            "headers": {
                "Authorization": "Bearer {{dasApiToken}}"
    "adsk3LeggedToken" : "{{adsk3LeggedToken}}"
{{adsk3LeggedToken}} is a valid token that when used in other calls works perfectly (e.g. Get Hubs, Projects... etc)
Still, when trying to open a cloud model I am getting the following error.
Autodesk.Revit.Exceptions.RevitServerUnauthenticatedUserException: You must sign in to Autodesk 360 in order to complete this action.
[02/09/2025 14:20:40] at Autodesk.Revit.DB.ModelPathUtils.ConvertCloudGUIDsToCloudPath(String region, Guid projectGuid, Guid modelGuid)
[02/09/2025 14:20:40] at NebulaDA.Revit.DB.ExternalDBApplication.DesignAutomationReadyEvent(Object sender, DesignAutomationReadyEventArgs e)
Despite spending a lot of time on this, I still don't know what may be going wrong 😞
Could anybody please help me out with the solution, thoughts, ideas?
Thanks!
ricaun
I was testing that adsk3LeggedToken, some weeks ago and was able to make work with no problem.
You could check if the user changed and the login userid is available.
Console.WriteLine($"Username: \t{application.Username}");
Console.WriteLine($"LoginUserId: \t{application.LoginUserId}");
I suppose the 'You must sign in to Autodesk 360 in order to complete this action.' only happens when the user is not login.
Here some references:
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
peter_sylvester
Seemingly during the execution of the activity there is no user logged on ! 😞
[02/10/2025 12:16:53] ===> Username: acesuser
[02/10/2025 12:16:54] ===> LoginUserId:
My Workitem thou DOES Include the 3Legged access token
Request Body
    "activityId": "NVCloudManagerDA.NVCMActivity2024+test2024",
    "arguments": {
        "NVCMParams" : {
	    "url": "data:application/json, [{'Region': 'US', 'ProjectId': '062b8c8b-d33b-473f-9760-xxx', 'ModelGuid': 'c20b5561-4f6b-4eb1-b9b7-xxx'}]",
    "result": {
        "url": "urn:adsk.objects:os.object:nv_cm_bucket/nv_cm_output",
            "verb": "put",
            "headers": {
                "Authorization": "Bearer eyJhbGciOiJSUzI1NiIsImtpZCI6IlhrU............7CFT7KL2A"
    "adsk3LeggedToken" : "eyJhbGciOiJSUzI1NiIsImtpZC......7kg"
Any Ideas about why is my user not logged in?
Appreciate your help.
ricaun
The only thing I'm doing different is that I'm using the Design Automation c# sdk and the only way I found to enable the adsk3LeggedToken was using a StringArgument and that result in something like this:
  "activityId": "ricaun.RevitAddin_DA_Tester2022Activity+dev",
  "arguments": {
    "input": {
      "url": "/Masked:url",
      "verb": "get"
    "output": {
      "url": "https://cdn.us.oss.api.autodesk.com/Masked:url",
      "verb": "put"
    "adsk3LeggedToken": {
      "value": "Masked:token"
I suppose both ways should work, I didn't test the way you are doing like in the blog reference.
peter_sylvester
Duh! I've found it! Such a silly mistake!
My adsk3LeggedToken was OUTSIDE of the "arguments" scope when submitting the new WorkItem request!
Thanks  for your help!
Peter
