Alright, let's tackle this curtain panel width modification challenge. It's a common request, and while it might seem straightforward, the Revit API's handling of curtain panels and grids can introduce some nuances.
Understanding the Challenge
Curtain panels are inherently tied to curtain grids. Directly changing a curtain panel's width often means adjusting the grid lines that define it. We need to consider:
- Grid Line Manipulation: How to identify and modify the correct grid lines.
- Panel Constraints: How to ensure the panel remains within its constraints after width changes.
- Parameter Access: How to access and potentially adjust parameters related to width (if applicable).
Solution Approach
We'll break down the solution into steps, providing code snippets and explanations:
1. Identifying the Curtain Panel and its Grid Lines
Explanation:
- We first check if the selected element is a
CurtainPanel.
- We retrieve the
CurtainSystem host.
curtainPanel.GetEdges() provides the edges, and we extract the GridLine IDs.
- We filter for vertical
GridLine instances by checking the curve direction.
- We convert the desired width (4000 mm) to feet (Revit's internal units).
2. Modifying the Grid Lines
Explanation:
- We use a transaction to ensure atomicity.
- We sort the grid lines by their X coordinate to determine which grid line to move.
- We calculate the difference between the target width and the current width.
- We use
ElementTransformUtils.MoveElement() to translate the second grid line.
- The transaction is committed.
3. Considerations and Improvements
- Error Handling: Add checks for null values, invalid input, and potential exceptions.
- Parameter Access: If the curtain panel has width parameters, consider modifying those directly (if possible). However, directly modifying the parameter of a panel that is driven by the grid, is often not possible.
- Grid Line Locking: Check if the grid lines are locked. If so, unlock them before modification.
- Curved Grids: For curved curtain grids, the logic will be more complex and require curve manipulation.
- Unit Conversion: Always be mindful of unit conversions between millimeters and feet.
- Selection: Create a method that allows the user to select a curtain panel instead of sending in a panel element.
- Edge cases: The code provided assumes that the curtain panel is defined by 2 vertical gridlines. If this assumption is false, the code will fail.
- The Building Coder: The Building Coder has many examples of working with grids, and curtain systems. Search that resource for additional information.
Complete Example (with Selection)
This comprehensive approach should provide a solid foundation for modifying curtain panel widths. Remember to adapt the code to your specific needs and always test thoroughly.
