IExportContext Material missing Appearance Asset data
josepht21
josepht21
Hi everyone!
I am currently trying to retrieve the material properties from the AppearanceAsset using the IExportContext but I have encountered some issues. For some reason some assets do not have any property (asset.Size == 0), therefore when trying to search for any property like "BaseSchema" I get null.
The code snippet goes like this
public void OnMaterial(MaterialNode node)
var currentMaterialId = node.MaterialId;
Asset currentAsset = node.HasOverriddenAppearance ? node.GetAppearanceOverride() : node.GetAppearance();
var baseSchemaProperty = currentAsset.FindByName("BaseSchema");
What is weird it that the material does have the right appearance asset set, is there a solution for this or am I missing something?
Thanks in advance!
@jeremy_tammik
jeremy_tammik
Yes, that sounds weird indeed. I asked the development team for you.
josepht21
Thanks! Will wait for the answer on it.
jeremy_tammik
Please try this path to get the "BaseSchema":
  • material Id -> material element -> AppearanceAssetId -> AppearanceAssetElement -> GetRenderingAsset -> FindByName("BaseSchema").
This path can explain why the material does have the right appearance asset set. For the OnMaterial method, it is more context based(more dynamic as it's exporting).
For further testing, can you please send us a sample file and Macro script so that we can check what is happening? Thank you!
josepht21
Awesome! I will try that way. Thanks!
