Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Unlock the parameter
2 REPLIES 2
1287 Views, 2 Replies
Please let me know, can i set the parameter value when the parameter are read only and user modifiable (Both are true) in RVT.
2 REPLIES 2
jeremytammik
jeremytammik
You cannot set the value of a read-only parameter. Its value is probably controlled by the BIM constraints in a more complex way.
You can set user modifiable parameter values.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Jeremy Tammik
The Building Coder
in reply to: jeremytammik
