Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Make an addin usable by everybody
3 REPLIES 3
373 Views, 3 Replies
Hello !
I've developed an addin with Visual Studio for Revit and I would like to know how to give it to someone else.
Is it indispensable that my colleague install Visual Studio and run the project ?
Can I give him only the files (with the .addin file) , and, if we put it in the correct location, make sure that this will work properly ?
Best regards,
GM
Hello !
Best regards,
GM
3 REPLIES 3
Hi there buddy,
Copy your files x.addin and x.dll
to the folder, change the year where required...
C:\ProgramData\Autodesk\Revit\Addins\2017\
make sure view hidden system files is turned on so they can see the programData folder
happy coding!
Hi there buddy,
happy coding!
Hi @Anonymous
Are you sure this is enough ? It won't be necessary to launch it once with visual studio ?
GM
Hi @Anonymous
GM
Phil is correct. The .dll and .addin file is all that is needed.
