Units system in document
Hi everyone,
Here is my code to create a detail line. I want to create a line with 100mm in Length. But the length of the line is not 100mm as i need.
Thank you for your help.
    [Transaction(TransactionMode.Manual)]
    public class Command : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiap = commandData.Application;
            UIDocument uidoc = uiap.ActiveUIDocument;
            Document doc = uidoc.Document;
            View view = doc.ActiveView;
            XYZ startPoint = new XYZ(0, 0, 0);
            XYZ endPoint = new XYZ(100, 0, 0);
            using (Transaction t = new Transaction(doc, "Creat Detail Line"))
                t.Start();
                Units u = new Units(UnitSystem.Metric);
                doc.SetUnits(u);
                Line l1 = Line.CreateBound(startPoint, endPoint);
                doc.Create.NewDetailCurve(view, l1);
                t.Commit();
                TaskDialog.Show("Creat Detail Line", "Line was created");
            return Result.Succeeded;
jeremytammik
Internally, Revit always uses imperial feet for all length related units:
http://thebuildingcoder.typepad.com/blog/2011/03/internal-imperial-units.html
You need to convert your 100 mm to feet, e.g., using constants and conversion methods like these:
    const double _inchToMm = 25.4;
    const double _footToMm = 12 * _inchToMm;
    /// <summary>
    /// Convert a given length in millimetres to feet.
    /// </summary>
    public static double MmToFoot( double length )
      return length / _footToMm;
The Building Coder provides a large collection of discussions on the topic of units:
http://thebuildingcoder.typepad.com/blog/units/
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Mustafa.Salaheldin
As @jeremytammik indicated you need to convert the coordinates from millimeters to feet first in order to get the length correctly in mm units.
Please find the modified code:
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            UIApplication uiap = cmdData.Application;
            XYZ endPoint = new XYZ(UnitUtils.Convert(100, DisplayUnitType.DUT_MILLIMETERS, DisplayUnitType.DUT_DECIMAL_FEET), 0, 0);
                t.Start();
                t.Commit();
If this reply satisfies your need please don't forget to mark it as an answer.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
