Detect Current Ribbon Tab
Dale.Bartlett
Dale.Bartlett
All, This may be covered somewhere, but I couldn't find anything. I have a two ribbon tabs (one is a beta/test area). Sometimes I have exactly the same panel/buttons on both tabs; this is deliberate. When I execute a button push I would like to know which tab is active at the time to set some defaults in the called function. Ideas? Links? Thanks, Dale
______________
Yes, I'm Satoshi.
Dale.Bartlett
Ok, I used this:
Autodesk.Windows.RibbonControl r = Autodesk.Windows.ComponentManager.Ribbon;
foreach (Autodesk.Windows.RibbonTab t in r.Tabs)
   if (t.IsActive)
       MessageBox.Show("Tab Name = " + t.Name);
Unless there is a better idea, that will do. Thanks, Dale
______________
Yes, I'm Satoshi.
jeremytammik
Dear Dale,
Thank you for your query and solution.
It looks perfect to me, and I am not aware of any other sensible approach.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
p_smithBVN
Hi @Dale.Bartlett,
I am trying to adopt a similar setup for a custom addin suite we have. However the Beta version has trouble OnStartup, returning the below exception.
I understand what it's telling me but I can change the name of that Beta build tab to anything and it still throws the same exception. Furthermore, I can dismiss that exception and then open up Dynamo/Python/sharpDevelop and manually create the tab with any of the names that have failed and they create fine.
I was wondering if this was something you encountered at all? I have segregated all the underlying assembly information between the release & Beta versions, because it's the one VS solution but just getting copied to different locations in post build events depending on config, but that hasn't helped either.
Cheers, Pete
