Unable to debug Simple Revit 2019 Plugin with VS
t.a.gordeeva97
t.a.gordeeva97
Hi, I'm trying to master revit api, but I can open it in debuge mod. When I try to start debugging, revit starts but stops on the loading window (a small window with demo geometry) and nothing else happens . Start without debug works and Revit opens.  I attempt to alter debug setting but nothing helped me.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @t.a.gordeeva97 ,
Are you getting any error messages?
Could you please share with me the screenshot of the loading window you are getting?
Also, Please take a look at the below links
1) https://forums.autodesk.com/t5/revit-api-forum/debugging-in-vs-does-not-work/td-p/10596519
2) https://forums.autodesk.com/t5/revit-api-forum/advice-on-debugging-c-in-visual-studio/td-p/6496811
3) https://stackoverflow.com/questions/48706016/debugging-revit-plug-in-through-the-visual-studio-ide
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
t.a.gordeeva97
Hi @naveen.kumar.t
Thank u for sharing links. Unfortunately, it doesn't help in my case. I can share screenshot.Снимок.PNG
naveen.kumar.t
Autodesk Support
Autodesk Support
Sorry, I don't have a specific answer to why this didn't work on your end.
To me, this looks like a problem with Visual Studio.
One suggestion I have is
1)Open your Visual Studio Revit project
2)Open Revit
3)After Revit got opened, Inside Visual studio press Ctrl+Alt+P
4)In "Available Processes", Select Revit.exe
5)Click "Attach".
https://stackoverflow.com/questions/42158547/use-managed-compatibility-mode-or-enable-native-code-de...
I also recommend you search this Revit API forum for similar issues.
Some suggestions/solutions given by some experts in this Revit API forum may help you to resolve your problem.
Naveen Kumar T
