UI.FileOpenDialog Choose a folder instead of a file
GertjanvandenbroekVKAE
I need to be able to designate 2 folders for importing and exporting activities. But the file dialog does not allow for me to select a folder... only files.
So how would I go about asking the user for a folder using the revitapi?
jeremytammik
Use the .NET or Windows API instead.
I know that The Building Coder has implemented and documented such methods. Don't know where, though, off-hand.
By the way, similar questions have also been discussed right here in the past, e.g.,
https://forums.autodesk.com/t5/revit-api-forum/folderbrowserdialog-in-revit/m-p/8370066
Please always search before asking.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
I swear I did search for this topic before I created it. Probably just the wrong search terms.
Thanks for the suggestion though,I'll mark it as accepted.
But that folder browser dialog is all sorts of awful, isn't there a more elegant dialog option available?
