お世話になっております。
Revit2023を使用しておりRevitは初心者のため勉強中です。
[アドイン]タブ内に「土木構造物を読み込み」が見つかりません。
マニュアルには「土木構造物を読み込み」が表示されているため通常は存在するもののようです。
資料を添付させていただきます。
アップデートなどもしたのですが項目は表示されませんでした。
お忙しい中恐縮ですがよろしくお願いいたします。
Solved by jeremy_tammik. Go to Solution.
I translated your question for you as follows:
I can't find the add-in for Civil Structures
We become indebted to.
I am using Revit2023 and I am studying Revit because I am a beginner.
I can't find "Import Civil Structures" in the Add-Ins tab.
It seems that it usually exists because "Load civil engineering structure" is displayed in the manual.
I will attach the documents.
I did an update, but the item was not displayed.
I apologize for the inconvenience, but thank you for your cooperation.
Hi @Ishiduka81190203 (さん)San
Japanese:
システムに古いバージョンの Revit がインストールされていますか?
English:
Do you have any old version of Revit installed in your system?
Unfortunately, this is not the best place to ask such a question. Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Afaict from your description, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface.
In that case, you might get more optimal answers to a question like yours relating to product setup, optimisation, usage, and other end-user support issues in one of the non-API Revit product support discussion forums instead:
The people there are better equipped to address this topic than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
