Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Trouble creating wall
2 REPLIES 2
329 Views, 2 Replies
Hi everyone: I'm trying to make a simple add-in which creates a wall. It compile fine, but it doesn't works. What I'm doing wrong?
Here's the code:
Highlight.cs
using System;
using System.Reflection;
using System.Collections.Generic;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
namespace Walkthrough
   /// <remarks>
   /// This application's main class. The class must be Public.
   /// </remarks>
   public class Highlight : IExternalApplication
      // Both OnStartup and OnShutdown must be implemented as public method
      public Result OnStartup(UIControlledApplication application)
      	// Add a new ribbon panel
         RibbonPanel ribbonPanel = application.CreateRibbonPanel("NewRibbonPanel");
         // Create a push button to trigger a command add it to the ribbon panel.
         string thisAssemblyPath = Assembly.GetExecutingAssembly().Location;
         PushButtonData buttonData = new PushButtonData("cmdHelloWorld",
            "Hello World", thisAssemblyPath, "Walkthrough.HelloWorld");
         PushButton pushButton = ribbonPanel.AddItem(buttonData) as PushButton;
         // Optionally, other properties may be assigned to the button
         // a) tool-tip
         pushButton.ToolTip = "Say hello to the entire world.";
         // b) large bitmap
         Uri uriImage = new Uri(@"C:\globe.png");
         BitmapImage largeImage = new BitmapImage(uriImage);
         pushButton.LargeImage = largeImage;
         return Result.Succeeded;
      public Result OnShutdown(UIControlledApplication application)
         // nothing to clean up in this simple case
   /// <remarks>
   /// The "HelloWorld" external command. The class must be Public.
   /// </remarks>
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
   public class HelloWorld : IExternalCommand
   	// The main Execute method (inherited from IExternalCommand) must be public
      public Autodesk.Revit.UI.Result Execute(ExternalCommandData revit,
          ref string message, ElementSet elements)
   		Document doc = revit.Application.ActiveUIDocument.Document;
   		Transaction trans = new Transaction(doc);
        trans.Start("CreationMurAuto");
       //Create line
        XYZ start = new XYZ(0,0,0);
        XYZ end = new XYZ(100,100,0);
        Curve wallLine = Line.CreateBound(start, end);
        Level nivel = Level.Create(doc, 20.0);
		Wall.Create(doc, wallLine, nivel.Id, false);
        trans.Dispose();
Thank you
Here's the code:
Highlight.cs
using System;
   /// <remarks>
   /// </remarks>
         // a) tool-tip
         // b) large bitmap
   /// <remarks>
   /// </remarks>
       //Create line
        trans.Dispose();
Thank you
2 REPLIES 2
Revitalizer
Revitalizer
"trans.Commit()" is missing.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
in reply to: Revitalizer
It worked fine! Thanks a lot.
