11:39 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone: I'm trying to make a simple add-in which creates a wall. It compile fine, but it doesn't works. What I'm doing wrong?
Here's the code:
Highlight.cs
using System;
using System.Reflection;
using System.Collections.Generic;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
namespace Walkthrough
/// <remarks>
/// This application's main class. The class must be Public.
/// </remarks>
public class Highlight : IExternalApplication
// Both OnStartup and OnShutdown must be implemented as public method
public Result OnStartup(UIControlledApplication application)
// Add a new ribbon panel
RibbonPanel ribbonPanel = application.CreateRibbonPanel("NewRibbonPanel");
// Create a push button to trigger a command add it to the ribbon panel.
string thisAssemblyPath = Assembly.GetExecutingAssembly().Location;
PushButtonData buttonData = new PushButtonData("cmdHelloWorld",
"Hello World", thisAssemblyPath, "Walkthrough.HelloWorld");
PushButton pushButton = ribbonPanel.AddItem(buttonData) as PushButton;
// Optionally, other properties may be assigned to the button
// a) tool-tip
pushButton.ToolTip = "Say hello to the entire world.";
// b) large bitmap
Uri uriImage = new Uri(@"C:\globe.png");
BitmapImage largeImage = new BitmapImage(uriImage);
pushButton.LargeImage = largeImage;
return Result.Succeeded;
public Result OnShutdown(UIControlledApplication application)
// nothing to clean up in this simple case
/// <remarks>
/// The "HelloWorld" external command. The class must be Public.
/// </remarks>
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
public class HelloWorld : IExternalCommand
// The main Execute method (inherited from IExternalCommand) must be public
public Autodesk.Revit.UI.Result Execute(ExternalCommandData revit,
ref string message, ElementSet elements)
Document doc = revit.Application.ActiveUIDocument.Document;
Transaction trans = new Transaction(doc);
trans.Start("CreationMurAuto");
//Create line
XYZ start = new XYZ(0,0,0);
XYZ end = new XYZ(100,100,0);
Curve wallLine = Line.CreateBound(start, end);
Level nivel = Level.Create(doc, 20.0);
Wall.Create(doc, wallLine, nivel.Id, false);
trans.Dispose();
}Thank you
