Transaction Exception
Mohamed.E.Salem
Mohamed.E.Salem
Hi my friends,
I am planing to use  bottom to select familyinstance (column ) then draw floor according to its position. so i used modeless form.but the problem as i understand the Revit API consider modeless form as  external application runing outside API context (I can't understand why) so i can't make transaction.Anyone can help me ???!
this message appeared
        public bool CreatedropPannel(CurveArray profile, FloorType floorType,Level level)
            Floor dropPannel;
             try
                if (profile !=null && floorType != null && level != null)
                // normal vector
                XYZ normal = XYZ.BasisZ;
                    // create floor
                   Transaction t = new Transaction(m_revit.ActiveUIDocument.Document);
                    t.Start("create drop panel");
                    //dropPannel = doc.Create.NewFloor(profile, floorType, level, true, normal);
                    dropPannel = m_revit.ActiveUIDocument.Document.Create.NewFloor(profile, floorType, level, true, normal);
                  t.Commit();
                    if (dropPannel == null) { return false; }
            catch (Exception ex)
                TaskDialog.Show("Revit", ex.ToString());
                return false;
            return true;
Thank you and best regards,
Salem
aignatovich
Hi!
Look at Samples\ModelessDialog\ModelessForm_ExternalEvent\CS sample in Revit SDK how to deal with modeless forms
